C
CX5_Pete
According to my Scangauge, there is a command for tranny temperature. I have a manual so it doesnt work for me. Useful for those that tow with the automatic.
He is correct about the cooler; however its not like the cooler you find on towing trucks. Its a small ass cylinder heat exchanger that runs engine coolant throught it if I read the diagram correctly. If I am mistaken, then it doesn't even do that and its just a small heat exchanger. Its probably a little bigger than the oil filter tbh.
fdew: Can your ScanGauge read transmission temps as well? I can see coolant temp with my current OBD software.
No, but if you read one you almost read the other. The heat exchanger between the two works both ways. If the transmission overheats it will raise the coolant tempature.
Which Scanguage do you have? If you have the recent Scangauge, the ATF Temp has to be entered in manually with X-Gauge Commands. The Scangauge website doesnt list the CX-5, but I am hoping maybe its just an outdated chart since it does include the Mazda3 and 6 for 2003+.
http://www.scangauge.com/support/x-gauge/mazda-specific/
All true. A liquid to liquid heat exchanger is much more efficient then a liquid to air cooler so it can be much smaller. The transmission heat exchanger does two things. When the car is cold the radiator thermostat is closed so the engine, engine coolant, and thus the transmission fluid heat up to operating temperature quickly (That's good) a external transmission cooler could defeat this. Once up to temperature the engine coolant thermostat and electric fan keep the coolant for both the engine and transmission at the proper temperature. I tow a trailer so I installed a scan gauge to watch coolant temp. I figured if I saw it going up I could adjust my driving before it got to hot. So far it has never gone above normal.
This guy has it right. It is a liquid-to-liquid heat exchanger and is very efficient.
Also unlike many conventional automatics, the Sky 6AT locks the torque converter for 90% of the time, which halts fluid shear within the torque converter; the primary source of heat in an AT thus bringing heat generation down similar to a manual trans. Also some advice, if you have to tow big trailers and heavy loads, don't cruise in 6th gear.
let me just excuse myself and interrupt this snarky ball-tugging session. Mazda's transmission does not have oil cooler lines to hook up a transmission cooler or to do a full fluid flush. you cannot install a transmission cooler on one of these units.
After 49 posts including "Wikipedia Mike's" nobody actually answered OP's question until yours almost 3 years later! Where were you when I made the same claim in the other thread?let me just excuse myself and interrupt this snarky ball-tugging session. Mazda's transmission does not have oil cooler lines to hook up a transmission cooler or to do a full fluid flush. you cannot install a transmission cooler on one of these units.
here is the cooler, water-oil
bottom right
Yeah I know your modified ATF heat exchanger would have no coolant flowing as you're going to leave the original cooler hanging with the coolant hoses.There will be no coolant flowing through the modified adapter. Worst come to worst, I'll put a tap to the ATF ports from inside of the contraption, when I cut it open. Regardless how the finned ATF internal line is arranged. Then I'm gonna screw in proper aluminum or brass hose fittings to the ports, and that's it. All I really need is a thing that bolts up to the tranny, with hose hook-ups to ATF ports.
Really hope to make a video of the whole ordeal, but then that's with a thick cigar and a glass of rum in hand in the backyard... Still hopeful!
Actually it'd be the best to find some enhanced aftermarket Mazda SkyActiv-Drive ATF/coolant heat exchanger such as this modified 4-port cooler for Nissan's CVT from China. This enhanced heat exchanger has 2 additional CVT fluid ports for an external fluid cooler. For our SkyActiv-Drive a transmission flush is now possible with these 2 additional ATF ports!
Did you remove the air box when you checked the ATF? If the mileage of your CX-5 isn't too high, I'd do an ATF drain-and-fill, may be twice or three times with one week interval.Thanks for this. I kind of figured this, but I didn't know if there was a creative work around or a place to tap into the transmission since all the parts stores show this as being compatible. It was worth it to get in there though and check the ATF dipstick. That stuff is darker than it should be and my wife has complained about it shifting oddly between 5th and 6th gear.
Here's "ATF / coolant heat exchanger" from Chris_Top_Her's failed SkyActiv-Drive transmission. It's a part of transmission hence there isn't an external ATF line to tap for an external ATF cooler.
yugrus came up with an idea modifying an OEM ATF / coolant heat exchanger with 2 AFT ports so that the transmission flush is possible. The best is some aftermarket manufactures can come up with a modified ATF / coolant heat exchanger added 2 ATF posts like they have done to many others.![]()
Those "enhanced" ATF / coolant heat exchangers shown are not available for our SkyActiv-Drive transmission. Make sure don't buy into dealer's recommendation of "flushing" your transmission with a "special machine". That can't be done, only drain-and-fill is doable. If your mileage is higher you may consider to replace ATF filter cartridge inside which requires some experience of applying the sealant gasket.I appreciate the help guys! I also saw those modified ones that add the two ports, it's still under warranty so I won't be adding that and she mentioned she wants a bigger suv anyways. I did take the air filter housing out to check this and I noticed the tranny fluid was a little dirty, so I'll flush that out. Thanks!
