Yeah you have to bring up the picture attachment、copy the URL、and paste it into "Insert Image" function.
FYI - doesn't always work. Tried it last week for my pictures and nothing got uploaded. So went with an external site
Had a feeling that was coming. [emoji106]Each to their own
Hate advertising on my car.
Wow - didn't know USA dealers actually put their details as a badge on the back of vehicles....
We just have a window sticker and the number plate frames (which I actually prefer so as not to touch actual body work)
There's no external "ATF cooler" for SkyActiv-Drive transmission but a "coolant core" inside of transmission. SkyActiv-Drive transmission has no ATF ports on entire transmission casing like other automatic transmissions.I'm gonna try this again, however this subject was discussed previously. Indeed there is a way do to ATF flush on SkyActiv transmission. I think this dealer did what I intend to do as well, when I get time. They probably have modified a spare ATF cooler, so that instead of circulating ATF inside of it, it gets two ATF ports to the outside. Quite easy, actually. You just need to buy ATF cooler and do some drilling and fitting.
Then they'd drain ATF, unbolt your cooler and let it hang by the coolant hoses. Bolt modified cooler on, hook up to the machine, and off you go. The machine isn't needed though, as you can just start the engine and be done in a minute or so with the complete fluid exchange. The pump will promptly suck the fresh fluid from one container, and dump the old into another...
NopeI've actually never seen window stickers. That's really lame. You are taking that off, right X?
What do you see? This is what I see.
Isn't 2 weeks a bit early to use clay?
Huh, OK...so you just see the links (like me), but the person who posted earlier from mobile saw the actual photos. Weird. Thanks for the tip -- I'll give it a shot next time! Kind of a convoluted way to post photos, but good to know.
Respectfully, this is not true. Just take a look at the heat exchanger, AKA ATF cooler for Skyactiv transmissions. The images are all over the internet. It is bolted to the block, 3 bolts, and it is out. Two gaskets for ATF ports that come with a new exchanger.There's no external "ATF cooler" for SkyActiv-Drive transmission but a "coolant core" inside of transmission. SkyActiv-Drive transmission has no ATF ports on entire transmission casing like other automatic transmissions.
