Project: "Last RX-7" by Herblenny
Thanks Antoine! You still in Japan? Did you make it out to the 25th anniversary Cosmo gathering?
If I had known earlier, I might of gone.. My best friend from college was going to japan and I was suppose to go.
Yup, still in Japan. Unfortunately, I couldn't attend the Cosmo meet this time...:( A couple Cosmo owners, one stationed in Japan and another from Australia went I believe...In fact, here they are in this pic...:D
http://myp.nikonimagespace.com/html...33wHnWROZB1MjBvBIYrc1y5x68IjoeXQvCgay19Q#i/15
Do you know if there are plans for a 30th anniversary meet?
Cool!!
Not sure about the 30th Anniversary but if they do it in the summer, I might go this time around.. especially if its near 7's day.
Update..
My car was shown under Exedy Clutch USA booth at the Formula Drift ATL..
with one of the Exedy Model
Right before leaving..
Engine bay shot
And finally link to the SpeedHunters feature link..
http://www.speedhunters.com/2015/07/meet-the-rotary-maniac/
Here are few of my favorite shots from Photographer Larry
Update..
For the past year, I been looking into getting a dash unit for track use. Mainly to monitor various sensors such as: Oil temp, Oil pressure, Water Temp, Fuel pressure, Boost, EGT, etc.. as you can imagine, this will clutter the cockpit with bunch of gauges and problem placing them all.
Also, pending what ecu you run some dash unit will not work. So, after searching.. came up with an idea.
Those of you whos been following this thread, I was lucky enough to acquire a Defi Super Sport Cluster. Super rare dash replacement that you can tie into your OE car harness and Defi sensors to replace your OE cluster.
1993-mazda-rx-7-defi-gauge-cluster
Well, Defi recently came out with something interesting.
http://www.defi-shop.com/products/smart_adp_w/summary_smart_adp_w/
A device you can hook up to your 2008+ OBD II port and stream real time info to your smart phone or tablet. Better yet, you can use their Advance Control unit and also stream Defi sensor(s) reading to your iOS devices!!
So.. I decided to give it a shot!
bought an iPad mini, and downloaded the app called "Defi Meter C".
App looks like this.
My friend at EVOR sold me a Carbon blank cluster surround, which I used it to mount the iPad mini.
And installed it in the car..
And here is the video of it running..
https://youtu.be/trH3fSAh80Y
They are coming out with some cool stuff!! such as logging program and even track logging.
How did you get that to work with the OBD2 of the rx7? Isn't it a bit too old?
Then again I imagine there isnt much left of the original ecu... :)
I'm using Advance Controller which hooks up to the Smart Adapter W which give me the Oil temp, oil pressure, fuel pressure, coolant temp, boost, and I tapped into OE Rev and Speedo which connects to the controller but only with Smart Adapter W for the controller unit will supply the rev and speedo harness.
More info go here: http://www.defi-shop.com/products/advance_unit/summary_adcu/
Fellow Mazda Owners!!! I need your support!!
I recently signed up for an online battle where top two finalists get to set their cars to SEMA Las Vegas. I am currently in battle round from top 16 to top 8.... And I'm the ONLY MAZDA left in this competition!!!
To vote for me,
click on the link http://tunerbattlegrounds.com/competitors/909-philip-sohn
click on the blue facebook button
click on the yellow star to vote.
If you can vote for me every day, I would greatly appreciate it. And if you can share the links with other mazda owners, thats even better!!
This Competition is all about the communities and without your support no way I'll be going to SEMA. So, please help me get this 22+ year old car to SEMA.
Also you can friend me on my facebook for updates!
My Facebook : https://www.facebook.com/Herblenny
Thank you for your support!
Its been awhile since I last updated this thread..
To start, I took some photo of the car 3 months ago..
Still loving the Defi/iPad combo!!
I'm going to update this thread more often since new projects are at works this year. Including my 3 Rotor Project..
Awesome update as always, Phil! How is that iPad Defi combo working out for you in terms of accuracy and reliability? Is it actually useful...As good as "traditional" Defi gauges? Are there issues, delays or annoyances going through the iOS / iPad interface?
Looking forward to you updating this thread and to your ****** project!
Sent from my iPhone using Tapatalk
There is a slight delay during start up. Usually takes about 15 seconds to connect via bluetooth.
once connected, signal response is un-noticeable. I actually like this as all the read out is just in front of you. Also with newer ipad mini, I can run navigation instead of this during a long cruise vs. watching parameters.
My new thing is going simple/clean interior. less buttons.
