Folks,
After a long time searching, and calling a few vendors, I can't seem to find any sort of gear ratio upgrade for the F-series transmission (F25M-R) on my 99 Protege. (Not going to swap to a G-series until this transmission blows, as I have a Quaife LSD in there)
I'm looking to make the gears taller with a turbo system rebuild underway, and I'm hoping for at least a final drive ratio increase.
M-Racing doesn't have them, nor does Syncrotech. Any other vendors to give a go with?
Thanks!
EDIT
SOLUTION!
So the Mazda 2 uses the F-series transmission, and I can (and will) get a 3.85 final drive from it ($200 cheaper if you have an SCCA membership and order from mazdamotorsports.com instead of your dealer).
Thanks!
EDIT
SOLUTION!
