So bad for the environment. Glad CA doesn't allow that s***
Salt is bad, road brine is worse.
I don't live in Washington state, I live in eastern Pa., and in my town it's always being applied before a possible storm. The municipalities around here pretty much soak the roads with it even if they think bad weather is coming. In that regard, it is much worse than road salt because the solution splashes up in the crevices of what's underneath the car. Stuff takes a long time to dry when applied on the roads. Garages around here pretty much agree it's the worse thing you can drive your car through.Road brine is typically applied as a preventative measure and is NOT worse than rock salt because it is applied at lower rates. Sure, spaying it directly on your car would be bad but that's not how it is used. Rock salt is the biggest corrosion problem for vehicles because the salt "rocks" are kicked up and can settle on top of mufflers, suspension arms, leaf springs, etc. where they slowly dissolve and coat the undercarriage with a more concentrated solution of sodium chloride than would ever happen with typical brine applications.
Washington State DOT uses some salt brine but the highway I travel most frequently in the winter is typically pre-treated with a magnesium chloride solution which is less corrosive than sodium chloride (salt). It works very well at preventing the problematic frost and black ice but, when it snows 3"/hour the only thing that works is manual removal with plows and blowers.
I've read the worst possible thing you can do is keep your car in a warm garage after driving over salted roads. If kept in the cold, corrosion is very slow. If kept in warm garage, corrosion will eat your car alive.
From the Valugard website:
"New test methodology, SAE J2334, shows that MAGNESIUM CHLORIDE is more corrosive than salt.
Corrosion is a bigger problem than ever before because of changes in the way DOT’s now de-ice the roads and highways. Over the past 15 years, it is estimated that the costs associated with corrosion caused by anti-icing chemicals have increased more than tenfold.
$30,000,000,000! is the amount that the Federal Highway Administration estimates that corrosion costs the nation’s transportation industry. A lot of this is due to the increased use of MAGNESIUM CHLORIDE.
Over 38 states are currently using some sort of MgCI or CaCl to de-ice their roads.
Magnesium Chloride attracts moisture from the air making it more aggressive than salt because it is active even when “dry”.
One engineer states “MAGNESIUM CHLORIDE is basically ‘liquid rust’. It clings to everything and it attracts moisture – and it does not wash off easily”.
Tractors and trailers can be harmed even more when they drive through counties using different de-icers. Picking up all three chloride salts – calcium, magnesium and sodium – makes corrosion even worse.
The downside to MAGNESIUM CHLORIDE and CALCIUM CHLORIDE as de-icing agents are varied and serious in terms of the potential increase in maintenance time and costs. State and local DOT’s may apply these chemicals prior to any snowfall, increasing the likelihood and degree of exposure to cars, trucks, and trailers. These materials are especially destructive because of their abiliity to cling to the underbody of a vehicle and re-crystalize as they slowly dry out. By nature they attract and absorb moisture from the surrounding environment, keeping them in a semi-solution state for extended periods of time, which multiplies their corrosiveness.
In terms of trailers, road chemicals may affect a variety of components: structural members, suspensions, support gear, and top and bottom rails, to name a few."
A number of the name brand pressure washer companies have undercarriage attachments for their units and if you do a search online you'll find a number of other units available that just attach to the hose end. I just built my own for a few bucks with PVC and a brass hose connector from Home Depot. Just takes few minutes to hook it up and give the undercarriage a good rinsing.
[/IMG]![]()
Don't turn it on until it's under the car.
[/IMG]![]()
That's a damn good idea... if you were to connect one of those soap dispensers to it you could add a basic solution (baking soda, dolopril limestone, or granular gypsum) to actually neutralize the salt mixture.. for any that doesn't wipe away.
