I was just about to ask if the signals will hyperflash. BLOOOOOOODY ANNOYING. Are cars still using old school electromechanical turnsignal flashers? Seriously. Any bulb should be replaced as needed. Now, my question is, will it hyperflash due to being a lower wattage, OR something to do with Can-Bus?
inlinev: depends on the bulb. Cheap ones are horrible. I've gone through many LED replacements, only to send them back. There are modern MUCH more bright ones, but cost upwards of 40$ each :-/ So, Xmas wishlist it goes
But I rather not worry about wiring up extra resistor.
I guess it'll be a much later add on. I only want to change it because I don't really like the orange egg yolk look. I switched out my Mini's side marker lights, and it made it look SOOO much cleaner to not have an amber blob in the white housing.
As for the interior, I have some 600lmish COB boards I snagged from aliexpress the other month. I might throw those into the trunk somewhere for additional light, compared to just swapping the stock bulbs out for LED. Heard most LED 31mm festoons are actually too big :-/
Odd that in the Sylvania list, the trunk and map lights are different # designations (DE3175 vs DE3022) but both 31mm replacements :-/ Ugh.
