wildcrazyjoker8
- 2002 Mazda P5
Okay so a little background. I have an 02 P5 manual that will stall if I turn on the AC. If the just the blower is running it is fine, as soon as the compressor engages when the ac button is turned on it drops the RPM down to sputtering when sitting still. If I rev at all and let it drop it stalls. This only happens with the AC and I do not have stall issues any other time other than getting the car warmed up, but I consider that pretty normal. I recently changed out to the Denso SKJ16CR-L11 plugs from the NGK V-Power BKR5E to see if it would help, but nothing. I also changed out the EGR to the Canadian version and that made the idle a bit smoother, but didn't changed the AC issue. Any ideas? The compressor clutch maybe dying? It blows cold air instantly when it engages.
