Remote start Help!
kdodson77
2003 mazda protege5
I have been doing some things to my recently purchased protege5 (fixes from the previous owners decisions) It had a alarm and I got a viper 5101 smart start system I have the basics done but I cant seem to find any consistency in the schematics that I have found online. I have the mp5 wiring manual pdf but it hasn't done me very much good(or im overlooking something there). If anybody could give me some info as to what wires are what I would appreciate it. I tested some with the volt meter. black=constant 12v one of the black/white wires is 12v switched I believe the other black/white is accessory switched?
Thanks
-Kevin
Black and black/white are 12v constant, black/blue is starter, blue is ignition, black/red and black/white are accessory. Locks are light green/red. unlock is negative trigger, lock is the same wire through a 1000 ohm resistor. parking lights are brown - or light green/black +. brake is green/yellow, and if you have an alarm it's ight green.
Thanks, I got the locks, lights and horn done the first night I got it. Even though I have what the wires are it is confusing me. On the alarm side it is...
Heavy gauge remote start, (H3) 8-pin connector
H3/1
PINK
IGNITION 1 INPUT/OUTPUT
H3/2
RED/WHITE
(+) FUSED (30A) IGNITION 2 / FLEX RELAY INPUT 87
H3/3
ORANGE
ACCESSORY OUTPUT
H3/4
VIOLET
STARTER OUTPUT
H3/5
RED
(+) FUSED (30A) IGNITION 1 INPUT
H3/6
PINK/WHITE
IGNITION 2 / FLEX RELAY OUTPUT 30
H3/7
PINK/BLACK
FLEX RELAY INPUT 87A key side (if required) of FLEX
RELAY
H3/8
RED/BLACK
(+) FUSED (30A) ACCESSORY/STARTER INPUT
Remote start input, 5-pin connector
1
BLACK/WHITE
(-) NEUTRAL SAFETY SWITCH INPUT
2
VIOLET/WHITE
TACHOMETER INPUT
3
BROWN
(+) BRAKE SHUTDOWN INPUT
4
GRAY
N/O or N/C (-) HOOD PIN SWITCH INPUT
5
BLUE/WHITE
(-) 200 mA 2ND STATUS/REAR DEFOGGER OUTPUT
What brand starter is it? And I'm assuming alarm/start combo. If you give me the model number I can try to find the install manual and tell you what needs to be hooked up where if thats what you need.
It is a Viper 5101 smart start. Sorry I responded so late. I had a lot of stuff going on with work.
The red, red/white, and red/black wires are all your 12v wires, they can be tied together and go to the black 12v wire in the car. The pink is ignition which goes to the blue wire in the car. Purple is the starter wire and goes to the black/blue wire in the car. Orange is accessory and goes to the black/red wire in the car. pink/white is your 2nd ignition (which you can change to act as 2nd accessory in programming, but it wont hurt the car if you leave it as ignition) and goes to the black/white wire in the car that acts as accessory, NOT constant 12v! Brown is the brake input wire and goes the green/yellow wire in the car (at the brake switch).
Purple/white wire is tach input and goes to the purple/white wire at the bcm, pin #48. It is under the carpet in the passenger footwell.
Any other problems, let me know.
