hornsfan10609
Certified Mazda Tech
- 2003.5 Mazdaspeed Protege x2
Need to find time today to install the FTC but I really need to get a wideband before I start throwing tunes on it blindly. Especially since it is boosting so much, it hit 13-14lbs on just wastegate pressure. I found my old Forge WGA so I am considering throwing that in there with an MBC to bump the boost up but I hated the forge when I had it, it would never hold consistent boost. The car feels powerful until it hits fuel cut.
You will see once you install it. It fits with the stock studs but when you try to use the included hardware you are 'supposed' to use it doesn't fit. That was the original gasket from that car.
got my turbo out and investigating the new seals and lines ill need to buy. didnt have any issues at all mating the turbo to the pope downpipe though? not sure what the problem you were having was horns. maybe just the wrong gasket?
