hornsfan10609
Certified Mazda Tech
- 2003.5 Mazdaspeed Protege x2
There are no leaks I have checked 8 times. Replaced the BOV and still no boost. If there were a leak big enough to not push 1psi it would register as a vac leak and it pulls 22-23in/hg of vacuum at idle. No leaks.
Even ran it with the WG vac line plugged and hit 1psi in reverse but doesn't even hit 0 on the gauge in forward gears and drops off.
