Mazda Cx-5 OEM Hitch + Wiring
OEM Mazda CX-5 Hitch/Harness removed from new car. All wiring, taps and control box included. Also included is the tow bar insert, and a pin.. It did not come with a ball. The wires simply use quick connect wire taps. The internal to external 4 Pin Connector is roughed up as it was very difficult to remove the leads from the connector so I could remove the external wiring (in my opinion, do not use the small grommet specified in the instructions, but use (one of) the larger ones under the spare instead so you don't have to bother with removing leads from that connector). It still clips and holds the leads as necessary. I didn't picture them, but I have the fishing wire specified in the instructions.
I have the install instructions for both available as PDF if you want to install it yourself.
A note on the instructions for the hitch; it mentions using 4 shims and notes them "as required" my oem install did not include these shims. It also mentions making a cutout for the bumper; you can probably get away with not using this, but it will be pushing on the hitch.
Harness Install: http://lib.store.yahoo.net/lib/yhst-24809172479195/cx5trailerhitchharness.pdf
Hitch Install: http://lib.store.yahoo.net/lib/yhst-24809172479195/cx5trailerhitch.pdf
I will do local pickup no more than 30mi from my location (San Antonio TX) Shipping can be arranged.
List Date: 10/4/2014
For more info, click here to view the original listing: Mazda Cx-5 OEM Hitch + Wiring
On Sale For: $130.00
********************/analytics/ga/mazdas247
Panjo not showing listed items, even though they show as listed for me.. still available pm
