Now that I am looking into it I may just buy a new seal for the compressor housing and fix the wastegate flap on the stock turbo, I don't want to keep removing the turbo but I think it may be worth a shot. I was able to hit boost in it so I know it works but I am afraid the internal seals are leaking not just the O ring on the compressor housing. Turbine housing looks fine, no leaks
I am a machinist at a turbo machinery shop. We do ones smaller than T25 all the way up to units with 36" compressor impellers and they DO NOT normally leak on their own. If the turbine end is dry but the compressor end is wet there's a few checks you can do.
1) Does the crankcase breather line still connect to the inlet pipe between the turbo and filter? If so, and the inlet pipe is wet, the oil is coming from there.
2) Is the compressor wheel visibly blackened? Is it oily? Dry and dirty indicates filthy air-filter. Wet indicates the above.
Causes of leaks at just the compressor are usually due to two factors; dirty air-filter causing a small restriction in the inlet which effects what we call "vaccum", for ease of explanation, though it's more like a lessening of ability to flow normally. This in turn lowers the air pressure against the mechanical ring seal allowing oil to escape. It does not affect any of the ability of the turbo to make air. The other is crankcase pressure but normally it will make both ends leak, but we've seen some interesting cases... Or it could be oil from the crankcase escaping through the breather line.
The o-ring between the backing plate and the compressor cover just seals boost in.
Let me know what you find. A picture is worth a thousand words.
