I need ur help!!
eeda80
2014 Mazda CX-5
I gotta change tires. But its included warranty usually? At the dealear shop? And how can i check its fine tires. How can i check there is a crack or not. Plz help me
You've made three threads already about tires. You don't need to make the same thing three times, you can reply in a thread you've already created.
Tires are not a warranty item, they are a wear and tear item and you are responsible to replace them at your own cost. End of story.
At best, it may come with a warranty from the tire manufacturer, but, it's between you and Yokohama(or, whomever), the dealer will stay out of it.
I agree that it is a tire warranty and one must go through the tire company. I however, think it should be part of the vehicle warranty because shared responsibility is usually bad as in, the tire problem was caused by alignment or no, the problem was caused by a defective tire and the vehicle owner is in the middle. ed
If it's a case of the owner needing new tires due to the mileage they have, there is no reason it would be covered under warranty. My OEM Toyo's only lasted me about 32,000 miles. In one of the other threads the OP posted they stated they needed 4 new tires, so I'm thinking it likely relates to how many miles they have. The OEM Toyo's only have a 300 treadwear rating, which is pretty low.
Also why they suck even more for wear if you lower the car (aside from looking absolutely ridiculous with the stock offset).
