lol its not that big of an area back there
You're right... I guess DRL's in the trunk is probably a bit overkill
So.. when replacing the trunk light, can I just disconnect the plug from the assembly or do I really have to disconnect the battery to be safe? lol
As promised earlier, here are the pictures of the new LED tail lights installed... Also I like the Mitsubishi Mirage
Hey guys! So, with a Touring model, I had issues use LED bulbs for replacing the DRL. Not only did VLEDs not know what to do, but other manufacturers and stores (O'Reilly's, AutoZone, etc) did not either, even though the 9005 bulbs matched perfectly. User @Kedis82ZE8 helped me figure the problem out with a decoder wiring relay kit. R1 is what matched with the CX-5. It took about ~15 minutes total of work.
Here are the results (and the bulbs I bought if anyone is interested):
(Looks like you are non tech) That looks like a fog light, not the DRL (your link). Unless the non techs have a L shape DRL vs the pw13. Also, keep in mind you've replaced your high beam with a lower power bulb.
But to confirm, by doing it this way, you no longer have true high beam headlights correct? Your HB's are now "DRL brightness only" -- that is, when your headlights (LB) are on your HB bulbs are either A: "Off completely" when driving in LB mode, or B: "Only as bright as your DRL's" when you turn the HB's on?I have the non-tech & they use 9005 bulbs.
I am eyeing on the new 2016 Mazda CX-5 LED Tail lamps and wondering if this is just a plug and play on 2015 model. What do you think? Thanks.
It has been a long time since I posted. Still have my CX5 (2 years on 2/15) with only 7500 on the ODO. Early on I put in some led DRL replacements but they failed and almost caused me other problems. I believe the bulbs are p13w for cars with the tech package. Who has these and where did you get them? I would prefer to stay away from iJDMTOY unless they have improved their product.
