i dont like how they stick out past the middle of the rpfs, yes i know these are safe and hold the wheel properly I just don't like the look.
Just run some 3-5mm spacers. Then you can use your old lugs
Just run some 3-5mm spacers. Then you can use your old lugs![]()
sure cause the 8mm ones i have installed now are not doing the trick.![]()
You do have extended studs lol. Then go like 12mm
^ Mexi-stance
dont part out... way to nice of a build to stop
Do the ms3 seats bolt right in?
Also, don't part her out! You know she still makes you smile ;D
Yes I am same one for the last 3 years without issues.
good to hear, i've been looking into these since my current battery is starting to go. Would you mind sharing the model number of the deka you went with?
Looks great JT, it has to be done at on point. So idk if you've mentioned it yet, but what car will you possibly be moving onto? Turbobrick? Lol
