I replaced the stock fog lights with Hella 90mm projectors and an aftermarket HID kit,
https://www.amazon.com (commissions earned)
these are super bright with a nice cutoff so no glare, here are some night time pictures
that's a black cat (shocked) about 150 feet away (
LOL ! ),
light pattern goes beyond the black cat about another 50 feet,
so about 200 feet total, give or take
install is slightly complicated, the stock fogs are
mounted to a black plastic bracket held on by three philips screws to the front bumper,
you need to remove the black plastic bracket first, then remove the stock fogs,
need to dremel to get the larger Hella projectors in;
then secure Hella's to plastic frame with heavy duty zipties
difficulty (I rate maybe 8 / 10)
but definitely worth it, the beam pattern is extremely
spread out broadly and uniform, no hot spots
