Don't know how, but after twenty thirty tries, I managed to get it work. I tried to review my memory at the moment I got it work, the overall procedure was about the same but here is something I had done:
btw, I have 13 Touring, Non Tech package.
1. Automatic gear is in "P"
2. After pushing the start key for twice, in less than 1 sec, i press on the brake.
3. I did not press buttons super fast, I only do it like a regular fast beat, like 1,2,3,4,5,6...etc, smooth quick and firm on each step
4. And I tried to connect quickly between the parking light switch and hazard light switch and when it goes back to parking light switch.
5. at last, while I still press on the brake, i started the engine while is has the handbrake up and in "P"
here is a step i don't remember which one:
6a. I shift first, and then lower the handbrake to verify.
6b. or I lower the handbrake first and shift next to verify.
(the whole procedure is step by step and nonstop until even after engine start)
The problem is after this, I repeated the procedure to see if I can reverse it, IT DID NOT.......I tried a couple times and the running light never came back on......lol
Hope this help and may be someone can confirm the reverse step.
