Is it only the Forester or is it all cars with CVT that burns oil at an unusually high rate? My mom drives mostly city and milage is low. Is that going to affect this issue more or less?? If I do decide to go for the Forester, maybe I'll have to get her to check the oil light every month???
The problem is the FB engine, which is now in the Forester (2.5L N/A) and Impreza (2L). There is some chance of oil consumption, you might get unlucky.
The CVT should not cause any problem on its own, though mild driving might cause improper engine break-in and exacerbate the oil consumption. The CVT (because it will load the engine less then traditional transmission) together with slow driving / short trips might not provide the ideal break-in conditions in the first few thousand miles. This will cause the rings not to seat properly in an engine that's already prone to oil consumption might cause higher consumption than otherwise.
I think the CVT in the Forester, on its own, is a good unit and you should not be concerned about it for your mom. I skipped Subaru for the oil consumption risk. I am very happy with my CX-5.
