jerseymods
- 2003.5 Titanium Grey MSP
All the more reason, I just hit 153k.
do you have the stock exhaust still?
Replace the sensor for the FPR, it's the one on the IM with the brown connector. Sounds like you have a massive vac leak, obvious from the boost gauge reading and your symptoms. Check for cracks in the exhaust mani/missing hardware, check for leaks around the IM, charge piping, injector seals, etc.Yeah I had a maf sensor pop up and a fuel regulator sensor. But I've had these two codes pop up multiple times before I've had this issue. Think they pop up because of maxing out the 5v range on the maf. I got a ssafc just haven't installed it yet cause I want to fix this issue first.
Stock S pipe and catback, catless SLS midpipe. It spikes anywhere from 10-14 psi but it holds about 8-9 through the revs.do you have the stock exhaust still?
yes the nut which mounts to the strut. If that isn't stupid tight it will clunk.
how the heck can the underpan look THAT good and the exhaust look THTA bad lol. im pretty sure thats fine, but i wouldnt try to take it apart without replacment nuts ect on hand. maybe just leave it until you get the desire to upgrade to an aftermarket exhaust.
the mount looks fantastic, but that isnt the one that commonly fails. if you can rock the motor, chances are the rear mount and front mount are broken. New exhaust? get new mounts at the same time. solid side mounts and front and maybe just inserts for the rear on a brand new oem.. the 70 and higher dm rear mount SUCKS.. turns my windshield into a great big speaker lol.
Corksport 2.5 apparently bolts to stock axle back so if its still good, could reuse it. You could try to find a corksport downpipe as well. Or the pope but that won't make to 2.5 without adapter ect.
Compromise will have to be made for what's available. Though I too like the stock exhaust note. Running mine stock with deleted cats.
Ps. My s and j pipes are less rusted if you wanted one and just went with the cs exhaust.
Yeaaaa that's phuced lol. You could do just the front one for now easily though. Rear one is a realy b****.
Solid sides and front if you can afford. For the rear it depends what you want. Solid.mount will drive and shift wicked but be noisy and rattly. I only have side inserts but I might go solid soon and a softer rear mount.
I've never taking it off the car or removed the heat shield even. But won't be looking to part with it til I get all my pope stuff and fix my mx3. Sadly this yellow bastard will be on blocks for the rest of 2014.
ps, for some reason i thought you were looking at the front of the car.. my bad.. you could just take that axle back to an exhaust shop and have a few flange/pipe end welded on. if you get corksport 2.5 it goes from the Jpipe back i believe. lots of people run the pipe with msp muffler to keep the noise down and keep a performance boost from the bigger exhaust.
i just cut the cats out and replaced with pipe but ill be going cs fairly shortly. cant beat the quality for the price.
