Swapped the vinyl factory wheel for a leather one, cost all $55
Nice, where did you get a leather wheel for $55? I'd do that swap in a heartbeat if I knew where to get that deal...
20140314_145011_Android by tuanies, on Flickr
Even kept the silver lower trim piece too. Brightens up the interior a bit compared to the all black of the stock wheel.
P1090663 by tuanies, on Flickr
Here is video of my winning run at the auto-x last week. Again, sorry for the really poor camera placement, it was my first attempt at in-car video, and I definitely learned where NOT to put the camera, lol. The comment from the starter while I was at the line was because he apparently saw some humor in my minivan being followed by the car that was behind me was the aforementioned fire-breathing tube frame "Miata" with 15" wide slicks that set FTD.
At the beginning you can hear the announcer call out the time of the MINI Cooper that finished 2nd with a 42.6 second run - his run was briefly good for first place in class until I ran my 41.9sec time. There was definitely more time left out there for me - I got behind at the fifth slalom cone, I could have been a bit smoother in the second half of the sweeper/360, and been a bit tighter in the second to last element before the finish.
Intercooler? In the US?
I also went chasing rattles (and painfully loud clunks). I pulled the rear shocks to tighten up the mounts. I was able to get another 3/4 turn on each before the hex key slipped. Also discovered one of the adjustments collars was loose again so it got another squirt of thread lock before re-installing. The rattle is thankfully gone but the LOUD clunk from the rear over sharp bumps continues to drive me nuts!!! Sending an email to BC for warranty support. This can't be normal.
Anyone have an idea why the stock rear shocks wont fit? I'm having a hard to trying to get the shock fit in between the trailing arm? It's like a really tight fit and no matter how much force, I cant get it to push through. Are there any tips and tricks? Because the Megan shocks I have slide through with no force. I need to go back to stock for warranty purposes.
Here's pictures from the user phunky.buddha. Hopefully its ok for me to use it as reference:
Finally bit the bullet and lowered my 2012 MZ5 with a set of Megan Racing 06-10 lowering springs. I kept my old OEM front struts and I am running KYB G-A-J mono tube rear shocks. So far it feels very nice and firm and not annoyingly stiff. I will have to report as time runs it's course.
If I understand what you're saying, the lower shock mount won't slide down into the perch? If you had a smaller shock tightened down in the perch it may have actually pulled the perch tighter than what the stock shock will fit. It may need to be massaged to allow the stocker to fit. The stock shock mount is a fairly tight fit to begin with.
Very nice! I still can't make heads/tails of a cones course. Gotta have my curbs.![]()
Today's lunch project was a back-up camera. $25 eBay special that clipped onto the factory license plate light. I used an Audiovox wireless video transmitter for the purpose since I didn't want to run RCA for video.
I notice that there's also a signal wire? For detecting if it's in reverse gear or something? Did you make user of that?Yep just used wire taps and put a peace of packing foam so it doesn't vibrate. Also taped and zip tied the wires down. And yes we probably got the sane camera.
