- 2009 Mazda 5 Touring & 2012 MS3
MR6, when you do spray it up, make sure you get all the rollers. There is one big obvious one when you look at each slide but there are 2 more above that one , 6 in all. The big one I think is the bottom roller to keep it from popping up off the track. The other 2 are the ones the door actually rides on. I would stay away from any type of grease as its going to collect dirt and is largely inaccessible to clean properly. You must use a thin spray with a straw to hit your mark and so that it makes its way in. Everyone is re-calibrating their effort to operate it, its getting slammed open and closed by the kids since it takes them a bit longerOnce it gets above freezing they should close themselves on level ground.
Will do. Thanks.
