Resuming Playback with 2014 CX-5 GT Tech Stereo and other issues
^ Haha, that's what I call wishfull thinking!
If anything "hardware" happens, it will be a means to keep some power going to the unit while the car is off. This is what happens with the 2013, and why it does not have the USB resume problem.
Are you sure that there is actually a difference in hardware between the 2013 and the current unit? I'm not too sure that the problem is a cut in power to the head unit when the car is switched off because otherwise the unit will also loose the memorised radio stations and possibly also the stored Bluetooth connection, like when the battery is disconnected.
I've had the battery disconnected and didn't lose the BT, or the stored stations, on my 2014 model.
Only the AFS light was on and needed resetting, along with the clock.
Yes. Different part numbers for the head unit. That actually annoyed a dealership when they had to replace the HU in my car... Apparently they got in a 2013 unit and it wouldn't work in my 2014.
I disconnected my battery this past weekend for a couple hours to install a remote start, and all AM/FM/Sirius presets were cleared. (Everything related to BT was retained, however.)
Take care
Gary
Sorry, my bad... It's the USB port that looses power, with the same result (1st song on startup, etc.)
I just rented a brand new 2015 Mazda CX-5. I did a quick test on the USB to see if the resume playback function worked. It was just a quick test but, if I'm not mistaken, the system resumed playing. Did Mazda fix this problem on the 2015 system? Does that mean there's an update available for the 2014?
I just picked up a 2013 CX-9 Touring edition without Bose. Using USB input, my 2nd gen iPod Touch works as expected and I can see all my albums, songs, and playlists. Restarting the car it takes what seems like forever (i usually make it to the end of my street) before anything plays and it always starts playing the first song alphabetically. I signed the petition for an upgrade. I'll try using Bluetooth the next time I drive.
Probably a 2014.5, as to my knowledge the 2015 are not yet out. And was your quick test shutting down the car and restarting within a few seconds by any chance? In that case, it will resume with all 2014s, since this is not long enough for the USB port to loose power.
Still no fix!
Date: Wed, 5 Mar 2014 11:44:37 -0800
Subject: Service Request 1-2174060
To: xxxxxxxxx
Dear xxxxxxxx,
Thank you for contacting us.
We regret to inform you that as of yet there are still no updates available for the USB port. Please feel free to contact your service manager at any time to see if any become available.
Thank you for your continued patience.
Sincerely,
NADEGE
Customer Relations Coordinator
MAZDA CANADA INC
800.263.4680 Ext.
[SR Number: 1-2174060]
To: mciep@mazda.ca
Subject: RE: Message from Contact Us on Mazda.ca - Technical Inquiries [INTR:195449]
Date: Thu, 27 Feb 2014 14:17:50 -0600
Hello Mazda,
Any update to this problem?
Thank you,
To: XXXXXXXXX,
Date: Mon, 6 Jan 2014 10:15:11 -0500
Dear XXXXXXXXX,
Thank you for your email.
At the moment, there is still no fix for the USB issue. Our technicians are still working hard in trying to rectify this issue so we may be able to provide an update to all of our customers. We apologize for any inconvenience caused.
Warm Regards,
Samantha
MAZDA CANADA INC
I'm probably going to have to do the same thing. I tried using BT but the car gets confused and tries to play music off my phone instead of the iPod. I tried to reconfigure it a few times and got it to do the right thing once...but it started playing something totally different. I give up. What a piece of junk.
I have Spoken to Mazda in Australia and they Confirmed they are working on a Fix and it will definitely Contain a Hardware Upgrade to the Bluetooth Module. I have a 2013 Headunit but also got my Hands of all the Internals from a Mazda 6, There are some differences in the Software and But Hardware Seems to be the Same. The Difference between the 2013 and 2014 is that USB is connected directly to the back of the 2013 while USB in the 2014 goes to the Bluetooth Module.
Hardware differences or not, aren't people having issues with both 2013 and 2014 models?
i have a 2013 CX9 and it doesn't work.
Apparently, the same issues found in the '14 CX-5 were also found in the '13 CX-9 (and maybe some other models). I don't know for sure whether the head unit hardware was the exact same one or not.
In any case, no, the CX-5 did not have the issue in the 2013 models.
Did you happen to get any information about what issues Mazda is planning to address, exactly?
Hi,
I have a CX-5 2014 and from New Zealand. I wrote into Mazda making a complain about the resuming playback issue. The reply was that Mazda has "advised that a fix for this has been identified and we are waiting for parts to be made available. At this stage we don’t have an accurate ETA, so can you please let us know your vehicle details to we can contact you when we have parts stock available?"
Below is the email I've got from them. My original email contains other 'complains' which I included to make it look like I mean business (evil)
Good morning Jason
Thank you for your feedback. The below email is a little long, but you did provide quite a bit of feedback which we appreciate. I have noted answer under each query and hopefully haven’t missed anything.
With respect to the Bluetooth and song / album functionality:-
The introduction of both grace notes and voice recognition (These features were added after the vehicle was launched in New Zealand) the bluetooth module now down loads all the song data from the paired audio device when the ignition key is turned on. This enables you the listener to select which song/s you would like to listen to, by artist, song name or genre using the voice control function. With this feature every time the car is switched off and restarted the song download is re-initialised. Unfortunately, in our efforts to improve functionality on one way, we have limited it in others.
Answer We are aware of this feature and have reported it back to Mazda Corporation for their attention. However we have been advised that a fix for this has been identified and we are waiting for parts to be made available. At this stage we don’t have an accurate ETA, so can you please let us know your vehicle details to we can contact you when we have parts stock available?
Other issues:
- Load time. Not only does it take 3-5 minutes for the USB drive to initially load, scrolling through songs, albums, and artists takes a few seconds to load EACH page of only about 10 items.
The drive should be indexed!
Answer This is related to the above concern above and should be repaired with new parts when available.
- USB play does not have play by folder functionality. A basic function in any MP3 player nowadays.
Answer - As above.
- Voice recognition could be better. Navigation system does not support voice recognition in New Zealand. Why is that ?
Answer - This is decided by a contractual / design agreement with the various markets that the vehicle is sold and unfortunately New Zealand missed out on this option
- No support for RDS-TMC Traffic Receiver?
Answer - This feature was not specified for New Zealand so is unable to be resolved.
- Bad trunk lighting
Answer - We can feed this back to Mazda Corporation. This is the first negative feedback we have received about this.
- No lock on the glove box
Answer - Yes that seems to be the trend these days on most new vehicles.
- Automatic windows. Sometimes when you park your car, you realized than you left some windows open. We all have done this one or more time.
Most cars will keep the juice flowing to the windows controls for a limited time or until you crack open the door so you can correct your mistake without turning the car back on.
What Mazda does instead is only give you ONE auto-up/down, illuminated window switch which will remain active after turning off the ignition.
All the other switches are left lifeless and dark. Either Mazda thinks people will only ever forget to close the driver side window, or they didn’t feel like wiring up the remaining the 3 (+ moonroof) window switches to a computer-controlled circuit and gluing in an LED.
Answer - These specifications change between markets and we were not able to option auto windows on all doors or "Global" Opening / closing of windows / sunroof.
I believe all almost all these issues are all fixable through a software update, whether put on a CD for consumers to install themselves, or through a dealer update.
Please consider doing this, to help both current and future Mazda owners which could be/or already ultimate loyal customers.
Answer- As we have noted above, some of the concerns you've identified are able to be fixed locally however where there is a specification decision for our market , we cannot change these items.
Some specifications are dictated to us by Mazda Corporation, others are dependent on Australian specifications, and other decisions are made based on cost and as you will understand the more features you include the higher the final purchase price so in all cases it is a balancing act to get the Features Verses Cost ratio correct.
We are continually reviewing our vehicle specifications and do adjust these where possible for the benefit of our valued Mazda Customers, and we will certainly feed your comments back to Mazda Corporation.
Best regards
Terrianne
-----Original Message-----
Sent: Tuesday, 25 February 2014 10:11 PM
To: Info Mall
Subject: Form submission from: Send an enquiry
Submitted on Tuesday, February 25, 2014 - 22:10 Submitted by user:
Submitted values are:
Hi,
I recently purchased a CX-5 Limited 2014 model.
As a proud owner of your vehicles, I feel as though Mazda is lacking in a few areas. I feel conned thinking about it.
Don't get me wrong, the vehicles itself is remarkable in many ways but it is subpar in terms of quality and satisfaction.
While they're not end of the world problems, it is annoying to the max knowing that I paid more than 50 grand for it.
My main issues is with the Infotainment/navigation system...
Music starts from Track 1 on USB (Flash Drive) on car start. It doesn’t remember the last song/artist/album played from a USB drive.
So it plays the first alphabetical song on the drive every time you start the car.
i.e
I played some songs, stop the car, get down and do my errands, come back, restart the engine, the song starts back from the first song again.
It does not resume from where it last stop. When I did a test drive, it was on a CX-5 2013 edition and it had no such problem. Dealer said 2014 edition will be the same if not better, which I believe. Why would a newer version be not as good? Indeed indeed... so can Mazda tell me why?
Don't tell me it's a feature as anyone with common sense would know that this is a flaw, either in design and/or in quality control.
If it was a decade ago when USB technology was not that mature than I might have accepted this. But c'mon, even my 2001 car head unit is able to resume from where it left off. If someone was listening to audio books, they will need to start over from the beginning every time? The poor fella will never get to finish his book!
I'm sure the head-unit has memory capabilities, it saves radio station presets, etc. Why wasn't this obvious? It wasn't a problem in
the CX-5 2013 edition so something must have gone wrong. I say lack of quality control. Or could it be lack of a better sense of what a customer/car owner want?
As a workaround, I tried playing from my phone via bluetooth. Bummer, I encountered speed problem instead. Everytime I get into my car, connect my bluetooth, it downloads information from my phone. While this being performed, I'm unable to play any songs via bluetooth till it completes (which usually takes a few minutes).
Again, really annoying. It also takes a few seconds when I try to switch to the next songs. A.N.N.O.Y.I.N.G.
Surely Mazda can come up with a faster, more reliable and user friendly interface other than this?
Other issues:
- Voice recognition could be better. Nagivation system does not support voice recognition in New Zealand. Why is that ?
- no lock on the glove box
Don't take offence if I sounded harsh... I'm just frustrated. My purpose is only to be heard and to know that Mazda will do something.
The CX-5 is very a nice car. Don't let these small matters take it down the drain.
I would love to hear back from you guys, or even better to know that some action has been taken and an ETA in sight for a software update.
Regards,
jason
Thanks for the update mcnosaj. I learned to live with mp3 cd's now but any upgrade is welcome and will be considered as a bonus.
I contacted Mazda customer support regarding the same issue and here is what i have got from them yesterday.
Thank you for contacting Mazda.
We apologize for the inconvenience that the infotainment system in your 2014 CX-5 might have caused you. Unfortunately, there are no updates relating to the operation of the USB or infotainment in your vehicle at this time. Mazda is still researching the operation of the infotainment system with certain smart phone and audio player devices, but we do not have any updates at this time.
Should you have any additional questions or need further assistance, please do not hesitate to contact me.
Sincerely,
Looks like they will introduce a brand new unit with 2015 model, similar to mazda 3 one, and will call consider it fixed.
I don't think the current ones will be fixed.
