So my '09 just turned over 86K and I'm wondering what I need to do maintance wise. Since the inital purchase in 2011 w/ 45K miles, I've:
So what's next? I need to look at the other motor mounts, I'm sure they will need to be replaced. So far all the sway bar bushings, etc. have held up remarkably well. I will do one more AT drain and fill with the next oil change and do that every 10K miles.
How about coolant? Brake fluid? They look good, but I'm thinking of changing that before it hits 90K.
Dropped and filled the AT fluid three times
Replaced rear shocks
New brakes
Two in cabin filter changes
Two air filter changes
New plugs this past Feb
One set of tires
Oil changes every 3-4K miles
Four tire rotations
Cleaned the MAF sensor
Cleaned the TB
Replaced the left side motor mount
New battery
