Good point. No real point in installing the motor and filling it with fluids ($) just to drain everything again... I'm just a nervous nancy and always triple check everything. But you're much better with wiring than I am.
I used high temp engine enamel on both P5's and they both turned out great. As you know, it's all about the prep work. I cleaned everything really well with Purple Power, then used about 5 cans of brake cleaner to make sure everything was grease free. Then about 4 cans of semi-glass spray paint (get yourself one of those spray paint handles). THe paint holds up pretty well to abuse and the silver P5's bay still looks good, I know the girl it was sold to so I see it around at meets every now and then.
You mentioned you were thinking a lighter color to spot leaks easier, right?
