Chumlet build thread!
Getting lower to the ground each day! Removed the rear spring perches today tucking tire front and rear almost as low as Alex was!
Lowering the front half an inch lower tonight, the rear is maxed out going to have to contact Ksport to get another set of rear springs so i have a set to cut
Do I spy a Home Depot lip on your car?? Trying to make the legacy of my car live on eh? ;)
Trying my best buddy I actually bottomed out on a friends driveway ripping that lip haha here it sits now
I hope everything is okay alex still super bummed your 2 is gone :(
Also @CRGracer24 I dono how you were fitting wider wheels then this im having trouble and these are only 15x6.5 haha teach me the ways!
Yeah man, everything's alright. Hopefully insurance is gonna follow through soon.
And check your PM's for the convo's we've been having! Just keep at her, don't give up!
As do I man no matter what happens I really hope you stay an active member on this forum!
And just replied... As always you have the answers to my questions thanks buddy my wheel and quick release according to tracking should be here on Monday I'll make a write up with pictures :D
Ever since I saw UnZipHer put an after market steering wheel in his Mazda2 I knew that is what I wanted to do. Heres a simple write up helping anyone who wants to put a wheel in their 2. :)
First things first you are going to need a new steering hub... Well if you hadn't noticed our cars do not have much aftermarket. Luckily the Mazda3 NRG steering hub fits our cars!! :D The part number for that hub is SRK-175H
Next comes the quick release, you don't need a quick release but I think they are pretty rad so i spent the extra for the NRG 2.0 quick release!
Third is the steering wheel! That is up to you as well just make sure to get a normal 6 bolt pattern wheel which is easy to find because they are everywhere!
Alright installation
First have a mazda2, all your parts, and the awareness that you are removing the steering wheel airbag... UNPLUG THE BATTERY!!!
Second gather your delicious parts and prepare for war
GOODBYE OLD WHEEL!!!
Third, there are 2 10mm bolts on the side of the scary explosive device that need to be removed!
You can see the hole on the side of the wheel there's one on the opposite side as well!
Fourth, after taking those bolts out the air bag will come off. next you must remove the 2 electrical connections behind the wheel, no pictures of the clips because it is very obvious and I wanted this airbag away from me so I was working fast!
Next thing to do is get the center bolt off of the wheel it is a 21mm bolt after that the wheel will come off freely :)
Last put the new steering hub on, it uses the same bolt you used to take off the original bolt. After the hub is secured attach your quick release then your wheel!
P.S. Sorry for lack of pictures in the end was just ready to drive if you and any questions what so ever you can reply or send me a PM the install took around 30 minutes!
DISCLAIMER: I"M NOT RESPONSIBLE FOR DAMAGE CAUSED TO YOU OR YOUR VEHICLE IF YOU CHOOSE TO PERFORM THIS MODIFICATION.
What did you do about the airbag light?
Well this 2 has had 2 different racing seats in it! So for over half it's life iv'e been watching that light flash. It's really not a bother I also have a TPMS light on because when I got new wheels Firestone had to order new TPMS sensor kits I said screw that just leave them out!
I did the racecar mod, electrical tape over the flashing lights I do not want to see.
-Derrick
