hahaha see what you did there lol thanksBerto I just installed that Wideband myself. Im trying my way to tuning with an SAFC for the time being.... pa chillar goma el 29 jajaja
Looking good, that's some great stuff you picked up
nice drawing all is perfectly clear thanks!I received your PM and I think the best way to explain you is by drawing you a clear schematic. Here's exactly how I plugged mine (except that I do not run with a FPR) and my car runs very good.
As I said earlyer, the wastegate/boost controller/charge pipe circuit must be isolated to be the most "trouble free" possible.
I decided to bring the Megasquirt its private circuit to prevent from false readings and engine blowing if other accessories get faulty.
You should get yourself a vacuum line filter for the megasquirt... it really smoothens the signal and brings the tune easyer.
Check this out for your megasquirt: http://www.ebay.com/itm/Turbo-Boost...Parts_Accessories&hash=item3f2882dd79&vxp=mtr
I believe I dont have that portI used the map line for the safc as well, that way both ECU and Stand Alone get the same reading. Dont know about the 1.6 mani, but the 2.0's has a vaccum pick up in the side, next to the VICS that goes to the MAP sensor. I " teed "that with a hard line thru the grommet and into the safc. Leave that only for those 2... let the vac block take care of the rest
They are installing the MS and tuning it hope to get it this weekendNice wheels! Will look great!
How's the turbo setup going?
tuner told me they should be okay for 10psi if they dont max out before, either way I am looking for a little more insurance just in case that wanted more power in the futureget some from a fs-de there cheap here
Could I idle normally with 750cc Injectors? I know they are to big!
That is good to hear!Running 850's with no problem.....I am running Microtech tho.
