Tried overfilling the tires and leaving them off the ground for 24 hours. Still have some tire noise....blah.
Hopefully it will go away eventually. Only really gets annoying at low speeds.
damn, what kind of tires are they? and im assuming they never made that much road noise before?
Hankook V12s pretty much brand new.
Honestly, I dont know if they were loud before. I put like 50 miles on them before the car ended up sitting for 6 months lol
I might try inflating them all to like 60psi again and leaving it in the air over the weekend.
Only other thing I can think is that I havent had the car aligned since all the suspension work so that might be the cause.
After putting clunk fix on, I still have clunking... But I think it's the end links, so my question is there a beefier version for the rear just like the ford escape fronts? Thanks
that could be it. i know usually if the toe is off itll cause some choppiness and cause more than usual road noise. i have the hankook V4 ES's on mine and theyre nice and quiet.
not really. I had clunk then I went back and tightened the poop out of the nuts on them and I had no more clunking. They have to be stupid tight.
get AWR adjustable endlinks i love them. was hearing negative things, and was having second thoughts... but they have worked awesome for me thus far.
We used air tools, so they should be plenty tight...
VIP... Are those the rear end links your talking bout? And how much they cost...
you cant really rely on air tools to tighten end links....you need a hex key to ensure the endlink stud isnt just spinning when being tightened....try it again, by hand, with a hex key.
yep, rears... they were about $100
http://store.awrracing.com/products...2d-Protege-1995%2d2000-%2d-Front-#3305Fr.html
Never removed end links when putting on clunk fix... I think they just need to be replaced
im not sure if they are from the factory but the MOOG ones at autozone are, plus they dont use the hex key design. cant think of the number but do some searching around the forum and youll find em. actually they might be from rock auto....
does anyone know if they make an aluminum radiator that will work with the stock side mount intercooler? besides for the 572$ awr unit
or even where i can find a new msp radiator
(nana)
Bought dem hood struts. What! LOL
pfft i don't want to hear it from you i see you all the time on msf. if i need to find you all i do is pull up a corksport product release thread lol. i think i can normally find you on the first or second page ahaha
