Just a question for both of you guys. I'm looking to get an HID kit as well. However, my current housings are so yellowed over, I don't think spending the money on a conversion kit will help much. So I'm planning to go all out on housings and bulbs in one go. Here are my options:
http://www.protuninglab.com/hidxe04...medium=adwords&id=18283950120&utm_content=pla
OR
http://www.360tuners.com/04-07mazda...rchrome.aspx?gclid=CKKCrN_P4LgCFUkV7AodgxUAmg
Any insight? Also would I need the 'Warning Cancelers', and what are those, anyway? Lol.
You don't need warning cancelers. Those are for cars that throw a bulb out warning light in the dash if a bulb lower than 55W is installed or burn out.
Aftermarket headlamps are not very good. Plus the HID kits in your two links are really cheap bad quality kits made in China.
Restore your headlights with this: http://www.xenonexpert.com/philips-headlight-restoration-kit/ and get a decent kit that won't let you down in 2 months: http://www.xenonexpert.com/volt-hid-conversion-kit/
In the end it will cost you less and you'll have better parts![]()
Hey, thanks! I'll actually order the restoration kit next paycheck. And then I'll look into getting the conversion kit afterwards! On your website I noticed that you've got bulb colors with the K ratings (I didn't see anything that pertained to 6000K - clear white). But I'm assuming that the higher you go the more colored it becomes? I'm wanting just a clear white that'll improve visibility, so anywhere from 4300-6000K for white and best visibility? Also I would be interested in high and low beams. Would you mind giving me a quick run-down on the bulb formats that offer them? (e.g. H4, H13, and 9004)
