Before any speaker change. Basically, the weather proofing for the inside door area, is crap from the factory.
I've never heard of that happening before. You sure that it's normal?
This is where I mounted my remote gain control for my JL subwoofer...
I originally looked at the Kicker Hideaway - but didn't think it would fit.. Good to know it does...![]()
Added a Kicker Hideaway last 2 weekends ago.
Thanks and if anyone has pics for pulling the HU, they would be appreciated.
Removing the HU is a snatch
I still have not figured out what to do with the empty center channel, any thoughts?
Hi Hollis,Why not just use a wire harness to the HU to avoid the wire cutting?
I run component splits; woofers in the doors and tweeters in the factory dash locations.. There is no speaker in the centre channel - and I don't think it needs it. I found with directional tweeters you can aim them to improve your front staging which for me was just straight up.
If using passive cross overs than you need to think about where to mount and cut into wiring too...
What size tweets? I was thinking Focal IS200 or possibly 3-way with 3.5 mids in dash and hide tweets in center facing windshield. Help is appreciated.
Did you install and how did you remove the HU to connect the Kicker unit? The Hideaway is out of stock in Crutchfield right now but I think a couple of these under the front seats should be good, since I would hate to lose any trunk space for those dog food trips to Costco. Thanks and if anyone has pics for pulling the HU, they would be appreciated.
