I have re-read my responses in this thread and realized that I sound like a complete a$$hole. For that, joecass I apologize. I somehow thought you were driving a brand new 2013 5, not a 2012 with 41K on the clock. Now, back to the matter at hand. I second what others have said about carefully tracking your mileage to establish what has changed. If at all possible, fill up at the same station two or three times in a row. Try to eliminate any odd, pattern wrecking trips also. You sound like me in that you have a set weekly routine for commuting. I also forgot that NJ doesn't allow you to pump your own gas, so you are at the mercy of the person doing the pumping, where I can control whether or not I top off (I always do, religously) Now that I think of it, that may be a LARGE part of what is going on. If the vapor recovery apparatus on the pump isn't working right and the pump auto stops early, and the pump jockey doesn't top off, you could be getting "short filled" Where you are taking on less gas with each fill, does that make any sense?
