I have been having problems with my rear sway bar flipping around and facing forward. When this happens, it drops the rear of the car down onto the tires and rubs the suspension together. Makes some real lovely sounds. :-/ Nothing has changed on my car suspension wise since last fall. Last fall I swapped out my Blue Tokico's for the new Tokico Illumina's because one of my rear struts decided to crap out on me. I also replaced the endlinks at the same time with Moog endlinks that are a bit beefier and have the grease fittings on them. I have the Illumina's dampeners set to 2 of 5. This all of the sudden started to happen about 3 weeks ago and I have to pop the endlinks loose and flip the sway bar back over and bolt it all back up at least once a week. It happened again last night on my way home. I didn't hit any potholes or anything. I just noticed that the car started having rubbing sounds from the rear and when I looked... of course it was flipped.
Any idea what is causing this and how to keep this from happening? It has now torn into the rubber jacketing on my e-brake cables. I need to get this fixed asap so that I can go back to driving my car to and from work.
THanks in advance!
THanks in advance!
