tailpipe spewing raw fuel
vinper
2003 protoge 5
What is the sequence of checking the fuel sytem , smoke an fuel coming out tailpipe . cannot drive vehicle . installed new plugs 03 protege 5
my daughter car she was driving fine started sputtering then died ,would not restart , I replaced battery and coil packs . as soon as i get it started fuel starts dripping out tailpipe . car is missing . I think has stuck injector at least 2 plugs were wet fouled1 plug had a brown ring around the porclean insulator
Be careful with your pre-cat,... you may have already wrecked it. (raw fuel on the pre-cat destroys it quickly)
Here is the procedure for checking the injectors.
The fuel system is covered in the downloadable Factory Service Manual (chapter 14 of the engine section)
http://www.floptical.net/mazda/
I'm more inclined to think you have an ignition problem. Were the two wet spark plugs connected to the same coil ???
my thinking is a bad fuel pressure regulator , and sucking fuel in to the intake plenum
OK,... I know nothing about that but here's where to test for fuel pressure:
Or even easier - pull the plugs - one that is super clean is being washed in excess gas and will be wet/oily.
Change that injector (or try cleaning it).
i check F regulator , pulled plugs , the center 2 cylinders are wet . I swapped in a coil pack .didnt help . here is a pic of the fuel vapor and dripping gas after 1 min of running . still no engine light
I think you should get one of these:
And do this:
That will rule out injectors.
The center two cylinders run off the same coil,... You may have a bad control wire feeding that coil (short or open).
Check for spark from those two cylinders.
If you've got no spark from either spark plug from cylinders 2 and 3 then check for a bad wire at the coil's connector.
I have the stethoscope all clicking , I saw they feed from same coil that's why i swapped a new one in. I gonna sent it to a friends shop dont have the time to screw with it . here's my car toy
sad to say this project has to go ,sold yesterday. 1970 judge clone 455 HO. if you dont know google orbit orange pontiac judge
