Ok I wasn't thinking when I was disassembleing the motor and didn't look as to what notches these were supposed to be on.. Can someone tell me if I got them right or not?
Put the crankshaft at TDC and the I on the intake side and the E on the exhaust side should be lined up. Without knowing what your crankshaft is at, we can't tell from that picture.
Nwvermind. Figured it out, both cam gears have to be in the same notch but it don't matter which one, as long as they are both the same
You need the cam gears to mirror each other the intake side should be a J and the exhaust side should be a L
Ok so in other words switch both of my cam gears to the other notch according to the picture I put up? I keep hearing different things about the position of these.
yes switch the cam gear to the other slot. i've times over 10 fs motors this way and it's also how they tell you how to do it in the fsm.
after that you will line the notches up like this.
