- '04 RX8
AEM intake on the way (pullup)
mazdaspeed777 said:Well I just reset the ECU and the didn't get rid of the CEL. To answer your question jeg I took off the vaccume lines and put caps on the places the tubes were connected to the intake manifold, and I just have all the sensors unplugged and hangin there since I took out the cruse control so there is nothing to plug them into. So what should I do now???
L8R said:When I did this, I drove around with the CC still attached and the harness unplugged for a week to make sure I didn't throw a CEL by having it unplugged. No CEL.
I removed the CC and left the cable, but just hid the cable and the plug. Your car should be fine, I don't see why you would have a CEL from that. Maybe a vacuum leak.
That sounds insane. How would you get to your fuses? My friend put his fuse box of his 240 in his fender well.
Good luck!
It wouldnt be much different than changing the fuses inside the car. I would put it somewhere under the dash that would be reachable. Possibly close to the fuse box inside the car.
There's nowhere feasable. Trust me. Best thing is pull the front bumper and stick it up under there. Basically, left hand side where a CAI filter would sit, or up under the rad support. Then you only extend the wires like 18" if that, and you don't have to pull it all back inside the car.
