Allenboy0724
What exactly does the +48 offset mean? Dont know much about these different type and sizes of rims and wheels?
As the calculator shows, it's the relationship between the mounting flange and the center of the wheel itself, which BTW has nothing to do with wheel width. If there is more wheel behind the flange than in front of it, pushed back under the fender if you will, the wheel is said to have a positive offset, what nearly every FWD car has.
If more wheel sticks out, sometimes called "deep dished" wheels, the wheel is said to have a negative offset.
From the factory and by design, our Mazda's come with either a +52.5mm (2004-2009,) or a +50mm (2010+) offset wheels. By installing +48's, and all else being equal, each wheel will stick out from the fenders another 2mm over stock (OE,) which is not a lot at all.
Go too far however and you begin to change the steering angle and things like steering angle/tire scrub and bump steer become issues, not to mention fender rubbing.
I hope that explains it a little better for you?
Yes. I feel as though you should never downgrade width on tires. Only upgrade.
rattle can or plastidip?
