the compression on the skyactives were originally 14:1 in japan, and they lowered it to 12:1 when they brought it to the us. that gives me a little headroom i think.
The other thing to consider is that the Skyactiv injectors fire twice before the spark, and this is not something that any off-the-shelf fuel computer is able to tune. The most straightforward way of doing it is probably going to involve tapping the intake manifold and running an extra injector rail to an AEM FIC. Then you have to somehow 1) fool the MAF into thinking that nothing is wrong and 2) maintain conservative enough AFR's through the downpipe that the stock ECU doesn't freak out. If you get those two within range I think you could lightly boost the engine, but you're probably going to break conrods left and right.Even low compression turbo setups can detonate without proper tuning. Direct injection helps because you're allotted more saturated fuel mixture which can allow you to run more aggressive ignition timing. Bumping the compression higher means the ignition has to be a lot more accurate or needs to be conservative which won't yield as much power. Too aggressive ignition timing causes hotter cylinder temperatures which is where detonation comes from. Same thing with runnin to lean of an AFR.
