Ive been searching this forum for info regarding the actual install of the 255lph walboro fuel pump, but with no luck. found alot of treads about the pump itself just none to install it. My problem isnt getting the pump out or anything its just that the walboro pump is physically longer than my stock pump and the clip that holds it in place does not fit over the walboro. So basically, either im dumb (quite possible) or theres some custom mounting work to be done here? i sort of assumed it was a bolt on replacment. any help?
