hooking up external transmission cooler NEED HELP!!!!!
quadracer1313
mazda protege5 2003
Everything is all done except i dont know which hose on the radiator is the inlet and which is the outlet???? please help
If looking at the front of the engine, the radiator inlet as at upper right (driver's side, by rad cap)...outlet to thermostat and water pump is at the bottom left...
There's one way to check. You may want an assistant.
With both hoses pointing into a used oil receptacle, have the assistant start the car (this can be you). One of the hoses will start pumping out ATF. Once you see this, tell your assistant to stop the car (or can you go back to the car and stop it yourself). Now, you know which hose is the inlet and which is the outlet. This will not damage your transmission unless you keep on running the engine for a long time. If it is anything like the engine coolant radiator, the hose that is placed higher on the transmission will be the feeding hot ATF and the lower hose is used to return cooled ATF.
