5AT gear ratios
I can't seem to find the factory gear ratios for the FS5A-EL tranny anywhere. Was wondering if Mazda used a different final drive ratio for transmission in the 2007-2010 5 than the 3 for the same years. Some manufacturers do that because of weight difference and fuel economy goals.
Courious, what will you do when you find out? Tranny swap or change gear?
Probably just grab a junkyard tranny out of a 3 if it has the numericaly lower ratio. I've seen several close by with 10-20k on them for about $350. I'm having some traction issues in 1st gear and would like to see if this would help my highway cruising mileage.
