The Eibach's are good. They are moderate lowering and have very good ride quality. As far as intake systems, there are many options. My suggestions are the SURE Aeros Full3(SRI & TIP in one unit), Cpe Nano SRI,K&N SRI and Cobb SRI. A Rear Motor Mount(RMM) is a must for this car, to keep the motor from moving around and getting the power to the ground.
springs will blow stock shocks in short order. Especially stock shocks with 77k miles on them already. Be careful dropping this car. Go too low and it bounces. Lose too much wheel travel and your handling will suffer.
You have a lot of research to do, so do it! I suggest going to msf.org and reading around. But tread lightly if you're going to post there. Lots of threads with info available in sticky form!
Koni Yellow struts and shocks, would be a good match for the H&R springs.Thanks for the information. I did figure i would most likely need new shocks especially after so many miles. I will definitely look into everything before i install anything. I will check ou the website. Thank you
