you can get both sensors for less than 100 IIRC
Direct fit ones run $110 upstream and $104 downstream from Autozone. Now, they have universal sensors for like $65/per that require wire splicing, but I'm not down with that.
rock auto friend, rock auto
I think a K20 would be a fun swap for the wagon. Too bad people want tons of money for those.
Mine looked exactly like that... (the underside of the VC) I gave it a bath and stuff, helped a little. I can smell it now, now just gross. The head was just as dirty too. I can assume you do your oil changes often? I ask b/c mine looked like that and my pal thought it to be b/c the p.o. Skimped out on oil changes...
Where's the blue gasket come from? Mines black and I got it from OMP. Just wondering
I had NO sealant on mine, except around where the timing belt section is. Wasn't replaced though, I assume.
What should have taken about 30 minutes, ended up taking an hour and a half. Either this was the factory gasket, or whoever changed it last used WAY too much sealant. I spent a good hour cleaning up the head and cover with a razor blade and brake cleaner. And, as promised, some pictures:
Not so clean...
well, I stumbled across the FE DOHC the other day.
That's definitely not the factory installation =/
You're only supposed to apply two pea-sized blobs of sealant near the cam sprockets, not all the way around...
Am I by chance a tooth off on the timing??
Sorry I keep linking to my photos. Im doing this on me phone. So freaking close I am!![]()
