What exactly are you soldering? Soldered connections tend to crack over time, crimping is the preferred method for attaching terminals/splicing wires.
You're not running those wires bare across the front VC are you?
Solder, when done Improperly can cause abnormal resistance readings. Then again, crimped connections create just as much if not more resistance. Crimped connections are fine for stereo, hid installs or even fog light installs. You know the simple stuff. Anything else, solder solder solder! But remember, less is more and always use heatshrink. Tape will eventually become brittle and I've seen it make some gnarly shorts...
I like the way the Techflex looks but it doesn't really seal the wires from moisture and would be a b**** to work with if I have to add some wiring. The splits stuff is tempting but I still need to add heat shrink to the ends and sometimes I can't get it over a plug or connector. I'm sure I'm going to have to go back and add/delete wiring after the car fires up so I'm just going to stick with the standard plastic wire loom for the time being. Maybe next year I'll rewire everything. But I agree it looks great.
Also, this is rubbish, the stuff I work with is made for ever changing wiring. It has a slit that allows wires to be put in or taken out. I can also cut the side of the channel to let wires out and create a new path. This stuff is so easy to work withTechflex would be a b**** to work with if I have to add some wiring.
Hmm... Maybe I'll order some from Circuit's eBay link (thank you, btw) to try out then. At least then I can say "There, I tried it alright, get off my back, guys!" haha
Evan Pm me your address ill throw some tech in an envelope and you can try it. I have all kinds of sizes and left overs from when i redid all my wiring.
This will work just fine and don't let anyone else tell you otherwise. Sure it doesn't look as nice (who cares) but when properly wrapped and sealed the split loom will protect your wiring better than the "Tech flex" stuff. All the external wiring in my RX-7 is covered with plastic split loom, wrapped in high-temperature electrical tape and contained with heat shrink at the ends.I like the way the Techflex looks but it doesn't really seal the wires from moisture and would be a b**** to work with if I have to add some wiring. The splits stuff is tempting but I still need to add heat shrink to the ends and sometimes I can't get it over a plug or connector. I'm sure I'm going to have to go back and add/delete wiring after the car fires up so I'm just going to stick with the standard plastic wire loom for the time being. Maybe next year I'll rewire everything. But I agree it looks great.
Evan, don't forget to pm you paypal so I can pay you. Also, don't feel bullied into using this stuff. We aren't hating because you don't use it, we just want you to know it looks good and is very easy to use. Way easier than running electrical tape in circle forever.
They do make high quality marine grade crimps. Super awesome, super water proof. I would loom\tape everything for moisture purposes, and if you are unhappy with the looks, techflex it for coverage!
