I believe my sway bar bushings are bad in the front. What size is the stock bar so I know which bushings to get ?
where can i order it from?
I got a Bosch one from amazon. For the Bosch sensors they have two part numbers in their catalog, just buy the cheaper one, the difference is in the length of the wire harness.
The OEM sensor I pulled off my car was made by Denso, Rockauto has Denso-brand parts for a decent price.
Cool ordered one but looked at the car and seen the car has 2 one on the upper side of the header and one on the lower side . Which one will I be replacing ?
Ah damn
Is this right
DENSO 2344752 Shipped
If so good and should I replace the other one too ?
No, you need Denso 2344721. I got a Bosch-brand replacement from amazon because it was slightly cheaper: https://www.amazon.com (commissions earned)
I wouldn't replace the bottom/downstream sensor unless it was detected as being faulty (eg. you have a CEL related to that sensor), its purpose is to monitor the primary catalytic converter to make sure it's still working properly.
thanks
i guess i need to do a list of things to buy/clean. placed the codes where they seem to belong on the parts that might be causing the problem.
buy cam shaft sensor (P0171 OBD)(P0340 OBD-II )
( P0300) put it under here because all my plugs.wires and coils are new. only thing under that code will be this sensor
clean maf sensor or buy a new one (P0102 OBD-II ) (P0171 OBD)(P0103)(P0102 )
buy o2(already done waiting for it ) (P0171 OBD)
buy ait sensor(P0113 )
^Damn that's a lot of codes
What I did today?
Picked up my block with forged goodies.
Aries 8.5:1 .020 overbore
Pauter Rods
ARP Main Studs
Full ACL bearings And Thrust Washers
Installed ARP Head Studs and Cometic ML Gasket
Gave it some HEAD(w/5 angle valve cut, Eibach EVS) and torqued it down
And installed ARP Exhaust Manifold Studs
so someone really needs to dip their car and keep it posted on how it goes.....i wanna repaint next year but that could be a winner.....i am thinking about doing my wheels soon.....
on a different note....does anyone have a msp axle.....i need to know the diameter of the shaft just behind the spline
I've dipped my whole front bumper while waiting for paint. I'm not a fan of their standard black on a whole car, Looks great for details, once you do a large surface, it looks drab and grey
Moar photos
