Geez. There's not gonna be much space between it and the firewall eh?
Pics installed? lolz. Can't wait to see how you're making that fit!![]()
Plenty of room. Tightest spot is near the brake lines. the rest is flexible/movable.
I only had a 5 hour window of time to test these out this feb long weekend. in 5 hours i have the stock im out, the new one in, made a little brace to hold the stock throttle cable a bit better than just the gsxr throttle bracket pictured, made a base map made off my previous itb map with the megasquuirt, got the car running well enough to idle and take a few drives down the street, then pulled the manifold and had it back together. its so nice working on a setup with plenty of room. i just need a proper tps connector from gsxr as i dont think i will ever have it run great without running alpha-N instead of just map. with just map using tricks with one way valves i can get it running decent enough to get around town and make good power at WOT but transitional and WOT to no throttle never seems to work too well no matter how i tune it. i think the gsxr tps is true linear and not just on/off so it should be easy enough to program into MS and sort out.
