The late start #1123 build
just got my wastegate on thanks to justanothermp5. cleared lean code, misfire code, rough idle,and weak boost.
[/IMG]
well clutch line blew up on me the other day....check this s*** out...
[/IMG]
then replaced it with a ss from corksport.
[/IMG]
and while doing my water pump i noticed my 120k mile timing belt....anybody want to guess on how long this wouldve lasted?
[/IMG]
wow that timeing belt is the worst iv seen, good thing you changed that out cuz if not, you would of had some bent valves wen ever it went out lol
I think one way may be the integral cams because they lengthen the stroke of the valve.
i see i see, i was thinking of somthing eles, well thats good to know, thanks! how did you find this info out?
just got my clutch and su front and rear motor mounts on and jesus do they make a difference....ill see if i can get pics later
