bikingpro5
- 03 Protege5
Since i have been asked a few times I've decided it might be a good idea to have a common thread that we can all share ideas/tips on the how/where to place the hood pins in our Carbon Fiber hoods. Yes people will say that they are not needed, but IMO anyone who has a car and plans to drive it with a CF hood should have the recommended pins. I have personally seen too many latches fail on CF hoods and destroy cars to not run them.
Firstly this is how i did my Aerocatch pins a few years ago before they came out with the new flush mount kits.
the latches
cutting the hole
hole under my hood that would not be needed with plate
flush mount plate
you can see in the plate kit you get a nice template to mark the holes once the pin has been parked out.
before using the 6 tiny screws/bolts to hold the latch
after with the plate
hole in hood you can see how much the latch actual holds (unpainted)
here you can see the plate under the hood and the alignment studs
now where i mounted the Pins was in a hole that was already there from the factory above the headlights.
finished latches
Now Joka1 recently did his Aerocatch latches
and Im sure Rob will also have some tips/tricks as to how he did his since he had the flush plates from the start and did not have to trim a huge hole under the latch like i did to mount the plate.
the latches
cutting the hole
flush mount plate
finished latches
