MSP, MP3, P5, Protege Parts. Motor Mounts, Body Panels, Stock Part Out, FS-DE Parts
Time for another wave of parts from my 2001 Proteg MP3. Please feel free to PM me with any inquiries.
1) When you PM me, please quote your replies. I do not have time to search my inbox every time I get a replied message, to remember which parts you want, your offers, etc... This will help me out a lot, so it is greatly appreciated.
2) Feel free to make offers. I'm more than willing to work deals, especially if you're buying multiple items. Just please save my time and your's and skip the lowballs...
3) I am busy, so I may not get back to you immediately that day. However, I am not a flake and I will ship items out as quickly as I can get to them.
(drinks)
AVAILABLE PARTS:
Prices do not include shipping!!!
The car had 116k miles to give you an idea of the wear on most of these parts. The motor was replaced at 83k miles and now has around 50k miles of wear. The transmission was replaced at 98k miles and something is shredded. The fork might have broken again and I'm guessing 3rd gear is all f'ed, but I don’t know for sure.
Exterior
03 MSP/MP3 Wing (HZ MP3 Yellow): $70
Trunk Bezel (Yellow Mica): $8
Stock Tail Lights (w/ Blue Batmobile Overlays on Reverse Lights): $35 ea.
MP3 Engine cover (valve cover's cover): $20
Foldable, Power Side Mirrors (black): $20 ea.
Rear bumper w/ Rear Lip (HZ): SOLD
Interior
Front A Pillars: $10
Door Sills: $15
Door Panels & Hardware: SOLD
Electrical Components
Fuse Box: $25
(2) Coil Packs: $10
NGK Ignition Wires: SOLD
(4) NGK spark plugs (extended ZE plugs):
Aftermarket Battery Tie Down (twin hooked): $5
Mechanical Components
Exedy Stage 1 Clutch (~35k miles): SOLD
Flywheel: SOLD
Clutch Slave Cylinder:
Throw Out Bearing (G15 (2002.5+)): $20
Output shaft: $30
Fuel Injectors (w/ new o-ring set): $9
Fuel Injectors : $6
Throttle Body (needs 2 IAC screws):
Radiator: SOLD
Radiator Fans: SOLD
A/C Condenser: $20
Water Pump:
Starter Motor: $30
Alternator: SOLD
Power Steering Pump: $15
PC Valve: $3
Drive Belts (Alt/WP & AC/PS):
Timing Belt (35k miles):
AWR Motor Mounts
AWR Front Mount (70 duro) (~8k miles): SOLD
AWR Rear Mount (70 duro) (~11k miles): SOLD
AWR Passenger Mount (70 duro) (~3k miles): SOLD
AWR Transmission Mount (70 duro) (~3k miles): SOLD
FS-DE Motor (~50k miles)
Valve Cover: $50
Intake & Exhaust Cam: $50
Cam Gears: $25
Cylinder Head:
Cylinder Head Bolts:
Oil pan:
Crankshaft:
Crankshaft Bearings:
Pistons:
Piston Rings:
Valves:
Lifters:
Retainers:
Feel free to make offers on any of the engine parts. I am tearing it down as time allows. If you request a part, I will be motivated to get it for you.
Wheels/Tires
(2) Stock MP3 Wheels (prepped and polished waiting for paint): $30 ea.
MP3 Center Caps: SOLD
Miscellaneous
Windshield Washer Fluid Reservoir (w/ pump): $20
(3) Windshield Washer Nozzles:
Coolant Overflow Reservoir: SOLD
Trunk Cargo Net: SOLD
Mazda Emblem:
Radio Connect Wires (Mazda side):
Radio Bracket:
Narrowband A/F gauge: SOLD
Lugnuts:
Shifter Pivot Hardware:
Exhaust Hangers:
Various Gaskets:
Miscellaneous Hardware:
Thread updated. Only the AWR front mount remains unsold of the 4 AWR mounts. I have a large workload from school this week, so I won't get much work done on the motor until probably next week since I work the entire weekend.
you have a 5 speed engine uncut harness??
No, it was sold a few months back.
im interested in the MP3 plastic engine cover, do you have the mounting bracket as well? 20 dollars + shipping to 28227?
I don't believe it requires a mounting bracket like the MSP cover. But let me check, because it's been over 5 years since I had that engine cover on the valve cover, so my memory is a little gray. lol
ucMP3, I never received a PM. Maybe you sent it to someone else.
My fault, I don't know who I sent that to, lol. You have a new PM.
Hey, im looking for an Intake air temperature sensor. Do you still have one? Also, can you pm a price to area code 84119?
Do you still have that air downforcer plate that sits on top of the grille? If so, I'm interested!
im interested in the side view mirrors anyway u can send me a better pic please or post one thanks please PM me i dont always check this. thanks
