MSP, MP3, P5, Protege Parts. Motor Mounts, Body Panels, Stock Part Out, FS-DE Parts
Time for another wave of parts from my 2001 Proteg MP3. Please feel free to PM me with any inquiries.
1) When you PM me, please quote your replies. I do not have time to search my inbox every time I get a replied message, to remember which parts you want, your offers, etc... This will help me out a lot, so it is greatly appreciated.
2) Feel free to make offers. I'm more than willing to work deals, especially if you're buying multiple items. Just please save my time and your's and skip the lowballs...
3) I am busy, so I may not get back to you immediately that day. However, I am not a flake and I will ship items out as quickly as I can get to them.
(drinks)
AVAILABLE PARTS:
Prices do not include shipping!!!
The car had 116k miles to give you an idea of the wear on most of these parts. The motor was replaced at 83k miles and now has around 50k miles of wear. The transmission was replaced at 98k miles and something is shredded. The fork might have broken again and I'm guessing 3rd gear is all f'ed, but I don’t know for sure.
Exterior
03 MSP/MP3 Wing (HZ MP3 Yellow): $70
Trunk Bezel (Yellow Mica): $8
Stock Tail Lights (w/ Blue Batmobile Overlays on Reverse Lights): $35 ea.
MP3 Engine cover (valve cover's cover): $20
Foldable, Power Side Mirrors (black): $20 ea.
Rear bumper w/ Rear Lip (HZ): SOLD
Interior
Front A Pillars: $10
Door Sills: $15
Door Panels & Hardware: SOLD
Electrical Components
Fuse Box: $25
(2) Coil Packs: $10
NGK Ignition Wires: SOLD
(4) NGK spark plugs (extended ZE plugs):
Aftermarket Battery Tie Down (twin hooked): $5
Mechanical Components
Exedy Stage 1 Clutch (~35k miles): SOLD
Flywheel: SOLD
Clutch Slave Cylinder:
Throw Out Bearing (G15 (2002.5+)): $20
Output shaft: $30
Fuel Injectors (w/ new o-ring set): $9
Fuel Injectors : $6
Throttle Body (needs 2 IAC screws):
Radiator: SOLD
Radiator Fans: SOLD
A/C Condenser: $20
Water Pump:
Starter Motor: $30
Alternator: SOLD
Power Steering Pump: $15
PC Valve: $3
Drive Belts (Alt/WP & AC/PS):
Timing Belt (35k miles):
AWR Motor Mounts
AWR Front Mount (70 duro) (~8k miles): SOLD
AWR Rear Mount (70 duro) (~11k miles): SOLD
AWR Passenger Mount (70 duro) (~3k miles): SOLD
AWR Transmission Mount (70 duro) (~3k miles): SOLD
FS-DE Motor (~50k miles)
Valve Cover: $50
Intake & Exhaust Cam: $50
Cam Gears: $25
Cylinder Head:
Cylinder Head Bolts:
Oil pan:
Crankshaft:
Crankshaft Bearings:
Pistons:
Piston Rings:
Valves:
Lifters:
Retainers:
Feel free to make offers on any of the engine parts. I am tearing it down as time allows. If you request a part, I will be motivated to get it for you.
Wheels/Tires
(2) Stock MP3 Wheels (prepped and polished waiting for paint): $30 ea.
MP3 Center Caps: SOLD
Miscellaneous
Windshield Washer Fluid Reservoir (w/ pump): $20
(3) Windshield Washer Nozzles:
Coolant Overflow Reservoir: SOLD
Trunk Cargo Net: SOLD
Mazda Emblem:
Radio Connect Wires (Mazda side):
Radio Bracket:
Narrowband A/F gauge: SOLD
Lugnuts:
Shifter Pivot Hardware:
Exhaust Hangers:
Various Gaskets:
Miscellaneous Hardware:
Motor Mounts
Motor
Transmission
Valve Cover
Camshafts
Clutch & Pressure Plate
Alternator, Starter Motor, Power Steering Pump, Cam Gears, PCV, Fuse Box
Radiator, Output Shaft, AC Condenser
Washer Fluid Rese & Coolant Overflow Rese
Door Panels
Door Sills & A-Pillar
Fender liner
Wing (HZ Yellow)
Rear Bumper
Tail Lights
Sideview Mirrors
Trunk Net
Engine Cover
Dang.. I was actually hoping for the stock one. Oh well, good luck with the rest of your part out!
Where did it go to anyway?
I don't recall exactly. Someone local that picked up a handful of parts got it.
how much for ur trunk net
List price is $20.
shipped to 93292 and the ngk wires
You've got a PM.
would u sell only the rear lip?...if so how much shipped to 33441
Yes, I'm ok with that although frankly its easier to keep them together for me. To get them apart I'll have to take some time and acetone or some other stripper to remove the body adhesive they attach the lip with. How I have the bumper/lip priced, I'm essentially just selling the lip and throwing in the bumper for free.
Pm sent for AWR RMM
Check PMs.
I'm intrested in the rear lip and door panels. Pm sent. Lmk shipping 33441
Check PMs
Dibs on the AWR pass and trans side MM's.
Check PMs
Payment sent for the pass and trans MM. Thanks, buddy!
Do you have the 'engine mount member' ? It's the part that supports the front engine mount , it bolts to the front of the car and the sub-frame. And how much to ship to 98230? Thanks.
