this thread is what i did today!
http://www.mazdas247.com/forum/show...ctors-with-Dual-CCFL-Shrouds-Retrofit-project
had this screw in the tire from last summer season and forgot about it. lost it this last weekend and been trying to figure out how to fix it since. i tried this Green slime which seemed to work and hold pressure in the carport, but after going from a drive, failed. twice..
so before i head to the tire shop and get laughed at, is this too close to the sidewall for some kind of plug? guestimate a 1/8 self tapping screw made this hole.
Anyone here using GTX gears? Are they really an upgrade and should I even bother getting them? Im taking the tranny apart either way and unfortunately PAR gears are way out of my budget and as far as I know no one really offers gears for that transmission anymore unless its custom.
I don't think they are much of an upgrade personally but i'm not a G15M expert.Anyone here using GTX gears? Are they really an upgrade and should I even bother getting them? Im taking the tranny apart either way and unfortunately PAR gears are way out of my budget and as far as I know no one really offers gears for that transmission anymore unless its custom.
http://www.frozenboost.com/product_...=1004&osCsid=c44c2d370e415e403491827562cc306cThis slim fan look good for the price ? Comes with the brackets an all as well .. and this time its black lol http://www.ebay.com/itm/12-THIN-SLIM-12-V-ELECTRIC-PUSH-PULL-BLK-RADIATOR-FAN-/290599134066
2 fingers wide(from the sidewall) was Merchants tire policy.hopefully it works out. im rolling on winters in the mean time. really dont wanna buy a new tire for a fricken screw. then the other 3 be a different size. though i guess i could just rotate it a bunch to get them close. these tires were 80% new last year when i took them off.
Just order these, plenty of members have (including me) and the shipping is fast.
As stupid as it sounds I have been wanting another Protege for a DD lately, I really only want a clean, low mileage blue MP3 for cheap.
And I am very happy with my clutch after adjusting the pedal yesterday, it engages fully now when I normally press the clutch and doesn't grind at all while shifting. Seems to help with some of the chatter but that's not going away until I replace the clutch eventually.
would be switched ignition. same one IIRC as the radio.So got a quick question. Need to know what wire to tap for my boost gauge so it turns red at night. Like a wire that only gets power when my headlights are on
There is a bolt on the firewall with a lock nut, loosen the lock nut (12mm I believe) and tighten the bolt in a few turns, then tighten the lock nut again. Then you adjust the pedal stopper to allow for enough 'free play' in the pedal. I can feel it fully engage before I hit the bottom of the pedal travel.how and where do you adjust the clutch pedal?
That's weird I used to drive a P5 and my insurance was within $5 a month difference between the P5 and MSP.I got a blue p5 to dd, wagon = cheaper insurance
